Recently, my car starting overheating on high speeds. Sometimes it does overheat in traffic jams as well but normally it overheats on high speeds like 80km/hr +.and starts cooling down while in traffic jam. This is extremely strange behavior.
So I performed a radiator flush to flush all the old coolant which was around 2 years old. After flushing, when I started to bleed the air out of system, I opened the radiator cap and started pressing accelerator pedal. Upon pressing the pedal, I noticed whitish milky type bubbles appearing on top water surface but then they disappear when I release the gas pedal. Again when I pressed the pedal, white bubbles appeared on water surface which goes away upon releasing the pedal.
Jul 30, 2019 at 12:07 AM
