Alternator noise most likely. Does it shift frequency as rpm changes? If so then it is feedback from the alternator. It could be through the wiring or it could be through the antenna. If it is something that just started then you will want to have the alternator itself tested for AC ripple as that is the common cause for the whine.
The way to test if it is coming in through the antenna is to remove the radio itself and unplug the antenna cable.
Is this the factory radio?
May 22, 2018 at 9:41 AM
