If one wire is red with a white tracer and the other is red with a black tracer, the connector is for the backup lights.
With the key in the run position, the red/white wire is the power supply. When the vehicle is placed in reverse, the switch closes and power travels through the red/black wire to the backup lights.
I attached the schematic below for you. Let me know if this helps.
joe
See pics below. Note: I had to cut the pic in half to make it readable. I did overlap the two so you can follow from one to the next.
Nov 8, 2023 at 8:45 PM
