Whining noise during acceleration
1997 TOYOTA AVALON
92,000 MILES • V6 • 2WD • AUTOMATIC
CPS21
The noise started immediately after the repairs were made in September and have gotten louder. Firestone soaped down the valve covers and the alternator was making the noise which made no noise before. I checked the parts listed and all checked out.
I would really appreciate your thoughts and hopefully a solution for the problem. Thanks
C P Siegenthaler
Fort Myers, Florida
Nov 18, 2019 at 1:36 PM
Often times a whining sound is related to low power steering fluid or a bad pump. Is it possible for you to record the sound and upload it for me to hear?
Also, does the sound change with vehicle speed or is it specific to engine RPM's
Nov 19, 2019 at 7:34 PM
CPS21
Thanks, not able to copy sound which does increase when accelerating and has started making a "gurgling" sound when going slow at first. I checked repairpal.com and it sounds the noise is from the PCV and or valve covers.
what do you think? Thanks
Nov 22, 2019 at 1:14 PM
I guess there could be a vacuum leak at the PCM. Is the vehicle running normally? A vacuum leak will cause a rough idle or even a misfire.
I attached a pic of the PCV. Check it as well as the hose that attaches to it for leaks. Those runs back to the intake manifold. If you remove the PCV valve and shake it, you should hear a rattle from it indicating the check ball is free.
Let me know if I can help.
Nov 22, 2019 at 9:08 PM
