Whining noise
2010 GMC YUKON
100,000 MILES • AUTOMATIC
ANDY1103
  • 13 POSTS
Noticing whinny/humming noise when accelerating and when let off gas stops. Transmission flush was done recently. Car drives normal besides this noise. Could it be differential? They recommended getting those flushed last oil change. Headed out of town next weekend, should I consider renting a vehicle?
Thank you.
Nov 26, 2018 at 4:11 AM
Good morning,
Does the noise change pitch when you turn the steering wheel?
Was the transmission filter changed with the service?
Can you take a video with sound of the noise and upload it so we can hear it?
https://www.2carpros.com/articles/engine-noises
Nov 26, 2018 at 4:42 AM
ANDY1103
  • 13 POSTS
I can try and upload a video today. Not a change in pitch when turn and I will check to see if they changed the filter as I am not sure.
Thank you.
Nov 26, 2018 at 5:00 AM
Sounds like a plan.
Nov 26, 2018 at 5:02 AM
ANDY1103
  • 13 POSTS
No filter was changed out. Just confirmed that.
Nov 26, 2018 at 5:24 AM
Okay, a clogged filter will cause the noise.
I would have the pan dropped and the filter changed out. Good possibility that could be your noise.
Nov 26, 2018 at 5:32 AM
ANDY1103
  • 13 POSTS
Is this something that we can do at home, or does vehicle need to be jacked up?
Nov 26, 2018 at 5:47 AM
You can do it at home.
Yes, it has to be jacked up to gain access to the transmission pan.
You will need a filter and about six quarts of fluid. Any parts store should stock these parts.
Nov 26, 2018 at 5:51 AM
ANDY1103
  • 13 POSTS
I hope you can hear it. I was taking foot on and off acceleration in hopes to hear difference.
Nov 26, 2018 at 10:18 AM
Good.
That sounds like a noise from the drive train. It could be differential or axle bearing.
You need to take this to a shop and have them drive it and give you an opinion. That is a noise from a bearing somewhere. Just difficult for me to give a good clue not being there.
Nov 26, 2018 at 1:22 PM
ANDY1103
  • 13 POSTS
Thanks! I have an appointment set up on Wednesday. In your opinion will driving it cause more harm?
Nov 26, 2018 at 1:30 PM
Not from the video. You have a short period of time to get it looked at.
Once they have an opinion, let us know the results.
Nov 26, 2018 at 1:33 PM
ANDY1103
  • 13 POSTS
Forgot to ask, in your opinion is it urgent to get looked at? We are planning on going out of town and wanted to drive truck. This might not be best idea? I am dropping off Wednesday. Hoping they can look at it, not appt specifically.
Nov 26, 2018 at 1:46 PM
No, do not go until the issue is determined. Then we can discuss whether you can take it on a long drive.
At this point, no, do not take it.
Nov 26, 2018 at 1:48 PM
ANDY1103
  • 13 POSTS
Okay, thank you! Hopefully they can squeeze me in and get it figured out. May rent a car just in case!
Nov 26, 2018 at 1:56 PM
I would have a back up plan, yes.
Let us know the results.
Nov 26, 2018 at 1:58 PM
ANDY1103
  • 13 POSTS
So here is the estimate of what is wrong $3,300.00!
Nov 30, 2018 at 5:31 PM
That is very, very high.
All the parts at rock auto are around $300.00 minus the fluid.
$3,000.00 for labor is a joke. It is about a six hour job. That is about $750.00. That means the job is worth around $1,000.00 to $1,100.00.
Nov 30, 2018 at 6:14 PM
ANDY1103
  • 13 POSTS
We thought the same! Took to dealership so figured was way high. Have to find mechanic now. I did not get a chance to ask dealership if all of the recommendations had to do directly with the noise we are hearing, they did a whole vehicle inspection. Thanks for your feedback!
Dec 1, 2018 at 7:01 AM
You are welcome.
Dec 1, 2018 at 7:24 AM
ANDY1103
  • 13 POSTS
This is what dealership explained to me. Photo did not attach before. Just wanted to add to the original question thread.
Dec 1, 2018 at 2:05 PM
Okay, thanks.
Still way overpriced.
Dec 1, 2018 at 2:10 PM
ANDY1103
  • 13 POSTS
In your option is the vehicle okay to drive long distances? Dealership said yes but little leary.
Thanks!
Dec 5, 2018 at 9:04 AM
Not in my opinion. You have bad bearings and those shavings are making the issue worse. Over time they will cause much more damage.
I would go the safe route and rent a car.
Dec 5, 2018 at 10:59 AM
ANDY1103
  • 13 POSTS
That is what I was thinking as well. We plan to get fixed after we are back from trip, renting a car for sure!
Dec 5, 2018 at 11:01 AM
Good deal.
Dec 5, 2018 at 11:09 AM
