The 48RE transmission on my truck, it shifts great after I replaced the TCC/overdrive solenoid, extreme duty upgrade governor solenoid, governor pressure transducer (sensor), output speed sensor with O-ring, 3-4 accumulator spring, and a new filter. But I still have another problem. I hear a whining/howling sound when I push on the gas that is very noticeable at low speeds when it is accelerating. It does not make this noise when in reverse, or park or neutral when it is sitting there with the engine running. Could that be caused by another part I have to replace? Thanks.
May 24, 2017 at 12:06 PM
