This is most likely a bearing noise. Normally when it only makes on deceleration it is something related to the drive shaft or drive gear bearings in the rear. If you are sure it is coming from the front then it could be a wheel bearing. However, these normally don't go away when accelerating.
Is this loud enough to get on a recording? If so, please post a video of it so I can hear it.
Also, the way to confirm it is not the driveshaft is to remove the rear shaft and put it in 4 high and drive the vehicle to see if the noise is gone. Clearly with your noise being a higher speeds you will want to do this in a safe place. Somewhere you can get up to that speed easily with out having to drive a long distance. Thanks
https://www.2carpros.com/articles/whirring-sound
Aug 11, 2019 at 11:43 AM
