When coming to a stop the engine dies and will not start. After a while it starts again goes for 500 mtrs or sometime 5 to 10 km no problem then does same thing again. car mechanic has changed throttle body part which he thinks problem but problem not solved . previously i took to another mechanic he scanned it and says TCM Error but i forgot to note it down may be P001 and P002 if it makes sense in error code terms. It appeared on screen TCM (Transmission Control Module) Fault/2 but it would not clear even battery terminal removed reset through scanning device please help if anyone have solution . there was no engine light showing up prior to first scan. now engine light comes on after changing throttle body but problem remained same.
Nov 26, 2016 at 9:49 PM
