Hi and thanks for using 2carpros.com
I would continue using what you have been using. As far as full synthetic, I have seen people switch to it after years of using conventional and the engine develop leaks.
With that in mind, use what the manufacturer recommended when it was built. Use a conventional 5w30 unless you are in temps under -20 degrees F Here is what is recommended:
Engine Oil
API Classification .................... Look for Starburst Symbol
Above -18° C (0° F) .................... 10W-30, 5W-30 (preferred)
Below -29° C (-20° F) .................... 5W-30 synthetic (preferred) , 0W-30
Jan 31, 2019 at 6:35 PM
