I know I have at least one actuator which has gone bad due to the clicking noise behind dash. I’m just not sure which actuator I need to replace. Is there a trick/tip in diagnosing which actuator has gone bad?
One other note, I think this is causing a parasitic drain on my battery. I have already replaced the relay in the SJB. When I pull fuses, #41 in the battery junction box is the culprit; however that fuse is for the SDARS and APIM.
Apr 20, 2020 at 8:47 AM
