Need to replace a transmission range sensor in the vehicle listed above Limited model. Trying to find the location of the TRS.
May 10, 2025 at 9:52 PM
CERTIFIED EXPERT
The transmission range sensor is inside the transmission; you will need to remove the fluid pan to get to it. Here is an image of the location which is on the other side of the mode control shaft. Check out the images (below). Let us know if you need anything else.
