Where is the transmission range sensor located?
2010 FORD ESCAPE
243,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
BURXINE
Need to replace a transmission range sensor in the vehicle listed above Limited model. Trying to find the location of the TRS.
May 10, 2025 at 9:52 PM
The transmission range sensor is inside the transmission; you will need to remove the fluid pan to get to it. Here is an image of the location which is on the other side of the mode control shaft. Check out the images (below). Let us know if you need anything else.
May 12, 2025 at 9:32 AM
