Switched tires RF and RR and followed the sequence you sent
LF relearned then RF failed. So, it failed in both locations.
So obviously there has to be an issue with sensors. Correct?
Originally Sam’s installed and it failed at installation so they replaced with another new sensor and never could get that one to learn.
They gave me the empty box Dill 5002 315mhz.
Can you think of anything other than sensor being defective? Hard to believe 2 would be defective.
I could break the bead and look at what sensor is actually in place.
If I order a new sensor does it have to be Dill or will another manufacturer work?
Apr 22, 2025 at 12:26 PM
