Where is the temperature blend door actuator
2014 FORD FIESTA
125,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
WYATT383
I have found the air mix blend door actuator and the blower position blend door actuator, but I need the temperature mix blend door actuator.
Feb 24, 2020 at 9:32 AM
Good afternoon,
The full dash has to be removed to gain access to the actuator. It is on the side of the heater case.
Temperature Door Actuator
Removal
NOTE: Removal steps in this procedure may contain installation details.
1. Refer to: Heater Core and Evaporator Core Housing - Vehicles With: Electronic Manual Temperature Control (EMTC) See: Housing Assembly HVAC > Removal and Replacement > Heater Core and Evaporator Core Housing (412-00 Climate Control System - General Information, Removal and Installation).
Feb 24, 2020 at 12:43 PM
