Where is the shift linkage located?
2004 OLDSMOBILE BRAVADA
98,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
CRAIGAK
  • 29 POSTS
I went to put it in drive and the shift lever moves freely but it's stuck in park. I need to see if the cable came off or if the bushing is shot, but I don't know where to look. Could you help? Thanks.
Feb 28, 2022 at 11:04 AM
SQM
  • 6,383 POSTS
This could be due to a worn component on the shift cable or a broken clip. You will have to remove the center console to access the shift cable.
It can also be due to a broken cable.
I have attached the diagrams for the shift cable as well as adjustment procedure below.
Thank you.
Feb 28, 2022 at 12:42 PM
CRAIGAK
  • 29 POSTS
Thank you. I appreciate the help.
Feb 28, 2022 at 2:39 PM
SQM
  • 6,383 POSTS
You are welcome!
Feb 28, 2022 at 2:41 PM
