So, the chime happens when the door is opened and the key is not in the ignition.
Key out, door open: Chime.
Key in, door open: Chime.
Key in, door closed: No chime.
Key out, door closed: No chime.
I was able to position the ignition cylinder with the pick that stopped the chime entirely and the key fobs worked without issue.
After I put the key into the ignition and start the car, the car runs turns over and runs without issue. When I remove the key from the ignition, the chime returns and the key fobs stop working.
Should I replace the entire ignition switch housing? Or just the ignition cylinder?
Sep 9, 2020 at 5:36 PM
