Where is the RCM located
2000 FORD EXPLORER
200,000 MILES • 4WD • AUTOMATIC
SEAN.G
Any ideas on location of RCM module?
Jul 29, 2020 at 1:57 PM
STEVE W.
  • 15,113 POSTS
Should be behind the foot well trim panel on the passenger side. Inside the lower A pillar. Just be careful if you are working around it, you can accidentally deploy the airbags if you don't proceed with caution. What is the issue you have that makes you need to locate it? Be advised it is not a plug and play part, it has to be programmed to the vehicle.
Jul 29, 2020 at 2:17 PM
