where is the heater control valve
2004 MERCURY MONTEREY
200,000 MILES • 4.3L • V6 • FWD • AUTOMATIC
TOM S LYONS
last YEAR HEAT ONLY WORKED ON THE DRIVERS SIDE NOW BOTH SIDES OUT OR AT LOWEST SETTING
Feb 2, 2014 at 6:11 PM
HMAC300
  • 48,601 POSTS
try pulling hvac fuse for 60 seconds with key on sometimes the actuator resets. if it still no heat then check actuators there is one for each side. if blower speed won't go fast check fuses underhood and relay. if speeds are none other than low then the resistor is bad and needs replacing. it's by the blower motor.
Feb 3, 2014 at 8:19 AM
HMAC300
  • 48,601 POSTS
forgot pic.
Feb 3, 2014 at 8:20 AM
