The fuel pump does not have a reset switch like a Ford does. Here is the location of the fuel pump relay, which is the engine control relay under the dash, but I have seen when you run out of gas the fuel pump goes out FYI. Here is how to change out the fuel pump in case you need it:
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Jun 3, 2023 at 10:30 AM
