2002 Chevy Venture. No right blinker. I found that the right-side amber daytime running light/turn signal bulb overheated and melted the sidelight assembly.
I replaced the sidelight assembly and all of the right-side bulbs front and back (as instructed from another post). Still, I could not get the right blinker to work.
After reading this post, I turned on my right blinker and then located the turn signal relay under the dash next to the steering column. I could easily feel it clicking. And yes, it looked like it was difficult to remove. Instead of removing it, I gave it a knock with my knuckle and it started working normally. All lights, signals, etc are good. If it fails again, I'll replace the relay. Your suggestion for checking the relay was correct. Thank you!!!
Jul 24, 2019 at 12:46 PM
