Every time I’m at a stoplight my car feels as if it wants to turn off like it’s running out of gas. When I put gas in my vehicle the gas pump stops pumping automatically as if it’s full when it’s not. I had my check engine light come on AutoZone said it was P0496 and I should replaced the fuel pressure sensor. I got that job done, but it seems that that was not the issue because after I got it fixed the check engine light came on after about 200 miles after driving. So after eight I went to O’Reilly’s and I had them check my check engine code reader and they said that I should change the EVAP purge solenoid valve or canister something like that .where is that in the vehicle? Or can I get some advice from you guys it’s listed above XE model 3.5 V6.
Feb 23, 2020 at 9:31 PM
