Where is the end of the AC drain line on a 2008 Town and Country
2008 CHRYSLER TOWN AND COUNTRY
110,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
RANGOONBOTH
Where is the end of the AC drain line on a 2008 Town and Country. It seems to be
clogged but I cant find it to clean it. I've jacked up the van but cant find anything on the firewall that looks like the drain line. Water is draining from under the dash on the passenger side and its not coolant. Thanks
May 11, 2015 at 7:00 PM
HMAC300
  • 48,601 POSTS
if this was built between june 07-jluy08 call dealer as there is a safety recall for a bad drain tube and it does exactly what you are talking about. it ruins the abs module. a new tube and grommet have to be installed. so check with dealer first, they may replace for free if not I have sent pics if you have to replace it yourself along with part numbers from Chrysler. I have left out a few details like push pins, an d after replacing parts due to space.
May 12, 2015 at 5:58 AM
