This is supposed to be the wiring for that car with auto headlamps. It does show a DRL module but not like the Crown Victoria has.
I wonder if the issue is not a bad lighting control module itself. It basically uses voltage signals from the switch to turn on the lights. It would be easy for a component to fail and stay on, especially a safety item like lights.
A dealer level scan tool can talk to the LCM and can test its functions as well as check it for error codes, it can generate a lot of them to do with lighting and other items as well. It would not be the first odd GEM failure mode.
It is also possible it is a wiring problem, The DRL module could have broken free and be stuck in the rad support with shorted wires. Or the wiring from the light switch to the LCM could be triggering it to stay on.
Just a couple items to consider.
Apr 14, 2018 at 5:40 PM
