No, no gas when you turn the key to the on position. But when you turn it over to start it you can see the fuel spraying out . is the a crank and cam shaft sensors?
Jan 21, 2020 at 2:00 PM
CERTIFIED EXPERT
No, this is not a sensor.
Can you take a video of this while it happens?
I am wondering if it is the ECM or if you have a timing issue such as a bad timing chain.
