So I did a "phone-a-friend" on this issue. Here's what we came up with.
Technical Service Bulletin (TSB) #04-01-38-008, issued by GM, deals with the issue of the air only coming through the defrost vents. Basically, there's some wiring behind the dash that is rubbing up against an edge. It has become damaged and is causing your issues. If this is the problem, you'll need to get behind the instrument panel (dash) and repair the wiring. Then, with the ignition off, pull the HVAC/ECAS fuse for a minute, put it back in, and then turn the key on for a minute (this is a reset/relearn procedure for the control head and actuators). After that everything should be ok.
Here's the TSB:
http://www.justanswer.com/uploads/SKeel1221/2009-04-21_142349_hvac_harness_yukon.pdf
If that doesn't solve the problem, then you'd need access to a fairly high-end scanner (a tech-2 scanner) which most mechanic shops don't have (at least not in my area), but the dealer does.
Aug 8, 2017 at 7:04 PM
