where is fuel pump fuse or relay
1981 CADILLAC DEVILLE
80,000 MILES
RANDY SHARP
  • 165 POSTS
1981 Cadillac Sedan De Ville. It has a 6.0 litre motor.It has been sitting for awhile.But I am not getting any fuel up to the motor.I drove in the driveway a couple of years ago since then it has just been sitting.And the manual I have it does't show where the fuel pump fuse is at at the fuse box.I can't hear the fuel pump when you turn the key on.I realize I might have to pull the pump,anyway but I want to see if it will fire first so is anybody can tell me or has a fuse box diagram I would appreciate it.Like I said it is a 368 cu. in. 8,6,4 motor and it has the two injectors on the throttle body.
Jul 12, 2013 at 3:52 PM
Randy:
I don't have the fuse box diagram, but why don't you check to see if there is power at the fuel pump relay under the hood. That way you will know if power is there, the fuse is good.
Jul 12, 2013 at 7:26 PM
RANDY SHARP
  • 165 POSTS
The thing about the relays they are all inside the car and I do not have a diagram for them
Jul 12, 2013 at 9:07 PM
I don't know why, but this just showed up in my mail. Sorry it has been so long. Have you had any luck with the issue?
Aug 10, 2013 at 9:24 PM
