Where is ECM located?
2006 CHRYSLER SEBRING
85,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
MRBARNARD
  • 10 POSTS
Where can I find the ECM on the car listed above Convertible Limited? I need to get the original ECM part number..
Jan 30, 2021 at 11:55 AM
SEVAG P
  • 405 POSTS
hello,
Engine control unit located driver side engine compartment, check the diagrams below.
Hope these helps.
thank you.
Jan 30, 2021 at 12:37 PM
MRBARNARD
  • 10 POSTS
Thank you! Those diagrams are different than ones I found. I was looking right at it but didn't know it was the PCM.
Jan 30, 2021 at 1:11 PM
SEVAG P
  • 405 POSTS
you welcome. let us know if you need more help.
Jan 31, 2021 at 10:01 AM
MRBARNARD
  • 10 POSTS
I do! Turns out, I can't find the number for the PCM so it can be replaced. Anyone know where it's supposed to be? The only number I located is part of the casting itself, which seems to be different than what is needed.
Jan 31, 2021 at 10:04 AM
SEVAG P
  • 405 POSTS
this number is the pcm part number 04829202ab of the picture that you attached. i will research to get your correct number.
Jan 31, 2021 at 10:27 AM
MRBARNARD
  • 10 POSTS
thanks again.
Jan 31, 2021 at 10:38 AM
SEVAG P
  • 405 POSTS
your correct PCM number is 5094318AD price 470.00$
thank you.
Jan 31, 2021 at 10:39 AM
