Low pressure fuel sensor location needed
2015 CHEVROLET EQUINOX
135,000 MILES
MONSTERLIIZ13
I been having trouble with my car.. It shows the check engine light when am driving it wont go faster then 40 or it will stall and at a stop it will shut off.
Mar 28, 2020 at 6:27 PM
I attached the location for the feed pipe fuel sensor which is what I think you mean by the low pressure sensor.
Which engine do you have? Also, can you have the vehicle scanned for codes to find out if that confirms a fuel pressure issue?
If you can't pull codes, just stop by a parts store as most of them do it free of charge. Thanks
Mar 28, 2020 at 6:44 PM
MONSTERLIIZ13
Sorry for the late response.
I have 2.4-liter, flex fuel.
The codes they gave me are P0191 and P0016.
Thank you for helping me out.
Mar 29, 2020 at 2:33 PM
Here is the diagram for the P0191. The P0016 is related and is actually mentioned in the description.
Basically this is finding to great of difference between the fuel pressure sensors.
The testing is attached so we need to run through this and see what turns up.
Let me know if you have questions and what you find. Thanks
Mar 30, 2020 at 8:44 PM
MONSTERLIIZ13
Sorry for the late response I haven't had a chance to get to the testing part but I'll do it tomorrow and I'll keep you updated.. And thank you for your help.. Is there a different way I can reach you faster if I have any questions ??
Apr 3, 2020 at 8:55 PM
Unfortunately, we have to keep all communication on this site. I know it is not the most convenient way but the idea behind it is that others will come that have the same issue you do can follow through our conversation and fix their issues as well.
I will keep an eye on my email this weekend and look for your response specifically just in case you need more help. When I see it, I will respond ASAP.
Apr 4, 2020 at 9:12 AM
LIIZ GARCIA
BTW, I'm MonsterLiiz, So the car decided to finally start running for a few days then it just stalled on my way home from work. the car just didn't want to run so OnStar had it towed for me to the dealership. I just got the car back. I was told I had to replace the timing chain or worse case scenario, new motor. I guess came loose so no compression. Long story short it luckily was just the chain. $2,800.00 sure beats $10,000.00. Oh please let me know if I was overcharged. Thank you for your help.
Apr 23, 2020 at 2:32 AM
Thanks for the update. That does not sounds out of line for that job. Especially depending on what part of the country you are in the hourly rate will vary.
Please come back to 2CarPros in the future.
Apr 23, 2020 at 4:43 PM
LIIZ GARCIA
At first I thought it was pretty high, but after I read the full invoice, it was a fair price. The price. Included oil change timing chain, guides, seals, water pump, tensioner and actuators.
Apr 23, 2020 at 9:42 PM
LIIZ GARCIA
Thank you for the help I really appreciate it.
Apr 23, 2020 at 9:43 PM
Anytime. Please come back in the future if you have other questions. Thanks for using 2CarPros.
Apr 24, 2020 at 9:49 AM
