Air conditioning wiring diagram
2001 FORD RANGER
100,000 MILES • 6 CYL • 4WD • MANUAL
UHSNOEBIRD
  • 342 POSTS
I am needing a wiring diagram ( with pictures ) for the vehicle listed above 4 x 4, 3.0L automatic. so I can determine where to put a plug in that's loose.
This plug in has 2 wires on it and it looks like it might be the high pressure connection, the location of this loose wire connector is on the passengers side of the truck near the front .
Jul 17, 2020 at 12:01 PM
I attached the wiring diagram for the A/C system. If this is on the right side of the engine, I suspect it is for the A/C clutch cycling switch. Let me know if you need more help figuring this out and we can go from there. Thanks
Jul 17, 2020 at 12:12 PM
UHSNOEBIRD
  • 342 POSTS
The loose plug in is on the drivers side up near the radiator, it's not the low pressure switch or the magnetic coil plug in.
The plug in will reach near the radiator on the drivers side.
Jul 17, 2020 at 12:27 PM
Okay. In the first post you said it was on the passenger side. If it is on the drivers side front, it appears that would be the high pressure switch. The switch itself is on the A/C line so you should be able to find it.
It appears that is the only 2 wire connector on the A/C in the front driver side of the truck. Maybe get a picture of it if this isn't it.
Jul 17, 2020 at 5:42 PM
UHSNOEBIRD
  • 342 POSTS
This is on a friends truck, I looked for that pressure fitting on the high side line, it doesn't have one unless someone changed that high side line. What do you think ? Can I use a jumper wire on this high side line for a minute or so to see if the compressor clutch kicks in, I think I should be able to. without any damage, let me know.
Jul 17, 2020 at 6:41 PM
Yep. It is a simple switch that just needs the contact closed so you should be able to jump it to test to see if that is why the compressor is not coming on.
Jul 18, 2020 at 6:45 PM
UHSNOEBIRD
  • 342 POSTS
okay, can you find a picture of the high pressure line that has the switch connection on it? because we cannot find one on this high pressure line that's on the truck right now. I'm not sure if this line has been replaced with one that doesn't have the switch on it for the plug in to go on. Thanks
Jul 18, 2020 at 6:56 PM
Check the compressor and see if it has the high pressure switch on the line coming out of it. Take a look at the diagram. I think the 3.0L and 4.0L are the same.
Jul 19, 2020 at 7:05 PM
UHSNOEBIRD
  • 342 POSTS
That is probably all the information I need on this truck, thanks so much for your help.
Watch who you deal with on that virus.
Jul 19, 2020 at 7:36 PM
Sounds good. Thanks for the update. Let us know how you make out.
You as well. Stay safe. Thanks
Jul 20, 2020 at 7:06 PM
UHSNOEBIRD
  • 342 POSTS
Thanks for all the info on that truck. I have a question on a 2002 Saturn exhaust system, can you look that question up and help me with it ? Thanks
Aug 16, 2020 at 2:12 PM
RENEE L
  • 1,260 POSTS
Can you please start a new question for the 2002 Saturn? In order for the site to properly index questions they need to be about the same car and issue.
For your convenience here is the link:
Before clicking on the link make sure you are logged into the site.
Thank you and have a great rest of your day!
Renee
Site editor
Aug 16, 2020 at 3:30 PM
