Codes P0119, P0012, P0022, and P0174?
2006 FORD EXPEDITION
213,000 MILES • 5.4L • V8 • 4WD • MANUAL
HISHIAHO
  • 8 POSTS
I just came from the auto part store and ask for a computers check cause my truck is acting like is have a misfire... so they go it connected and sure enough I have around 10 codes including 2 cylinders misfiring... the 3rd P0303 and the 7th P0307... if someone can help e with the location of this 2 elements it would be awesome... the other codes are P0119, P0012, P0022, P0174.
Nov 25, 2024 at 1:51 PM
These codes indicate the timing chain is worn out or the engine oil level is low or super dirty and needs a change.
P0012: "A" Camshaft Position Timing Over-Retarded (Bank 1)
P0022: "A" Camshaft Position Timing Over-Retarded (Bank 2)
Please start new threads for these codes individually.
P0119: Engine Coolant Temperature (ECT) Circuit Intermittent
P0174: System Too Lean (Bank 2)
Here is what needs to be done if the engine oil is clean and full. Timing chain guide and camshaft actuator replacement:
https://www.youtube.com/watch?v=dler2t2e4Zw&t
Please go over this video and get back to us.
Nov 25, 2024 at 4:45 PM
