when to do a change of antifreeze
2010 MITSUBISHI LANCER
80,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DINKSTER007
I want to know when is a good idea to change the antifreeze, and is a flush a good thing too? what type of antifreeze do i use? thanks
Oct 20, 2016 at 3:29 PM
HMAC300
  • 48,601 POSTS
our manual just states long life or equivalent which would be Dex-cool that has to be changed every five years. Most manufacturers do not recommend a flush, but you can if you want it is up to you. pull the lower hose off radiator and you will get a lot of the stuff that is bad out. just mix it 50/50 antifreeze and good water, or you can buy it already mixed it will take 7.0 quarts.
Oct 20, 2016 at 3:39 PM
