Front passenger side wheel shake at any speed after running over two wombats at 110 km.
Oct 16, 2016 at 7:25 AM
MHPAUTOS
CERTIFIED EXPERT
You are lucky that they did not rip out the front end. these little blighters are very solid and can do a lot of damage, yes check the tire and make sure that the lower control are is not bent as well, also check steering arm and caster rod and bush as well.
