ABS light turned on after replacing wheel hub
2001 CHEVROLET TAHOE
150,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
HULKSTER357
hello, I just replaced my wheel hub and after driving it a couple of miles, the ABS light came on? The speed sensor was checked and cleaned. What can cause the ABS light on after replacing the wheel hub?
Jun 8, 2020 at 9:14 PM
Good morning,
The hub should have come with a new sensor. Did yours come with a new sensor?
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Can you get me the code that is set in the system? It could be the sensor itself.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Jun 9, 2020 at 2:54 AM
HULKSTER357
Yes it did. But still showing that light.
Jun 9, 2020 at 4:53 AM
Okay, I need the code that is set to help you.
You can go to a parts store and they will read it for free.
Jun 9, 2020 at 5:43 AM
HULKSTER357
I will get it to you as soon as I go there. Thank you.
Jun 9, 2020 at 6:31 AM
You are welcome.
Keep me updated so I can continue to help.
Jun 9, 2020 at 7:21 AM
