Okay. That sounds like a tire. However, I definitely understand why you went for a wheel bearing because they are similar. Normally you can tell a wheel bearing when the pitch or rhythm changes by swerving the vehicle to load and unload the bearing.
The fact that you moved the tires and you said it moved the noise is good. I am not as concerned about if it sounds like it changed sides because noise like this can travel through other components and it sounds like it is coming from different areas.
If you want to confirm a tire, I would suggest swapping each of the rear tires with your spare and see which one makes the noise go away. I suspect it is only one tire but it could be both so you want to listen for any change.
If you find that this is in fact tires then I would suggest you replace at least two at a time both front or both rear and not just do one. If this is an AWD vehicle then you will need to do all at the same time or you can damage the transfer case.
Let me know what you find and we can go further if the spare makes no difference but if you changed it from the front to rear by just moving tires, then it is pretty sure to be a tire.
Jun 9, 2019 at 8:17 AM
