[quote:6196a7acc7="djscopper"]Steering problem
2006 Chevy Silverado V8 Two Wheel Drive Automatic 50000 miles
How do you replace the wheel hub assembly on my 06 chevy silverado?[/quote:6196a7acc7]
If this is a torsion bar style suspension, meaning it doesn't have springs in the front, you take the tire off remove the brake caliper assembly, remove the large nut in the middle of the rotor, and on the back side of the rotor near your c/v axle there are six bolts remove them . Now you might have to tap the old hub out by tapping on one side then the other,it is resessed in a little. you also may have to tap on the end of the axle a little to free it up in the splines. It is fairly easy if you are mechanicly enclined, good luck.
Feb 7, 2021 at 9:43 AM
(Merged)
