Wheel bearing
1997 HOLDEN COMMODORE
280 MILES • 3.8L • 6 CYL • RWD • AUTOMATIC
STEVEN CHARLES FENECH
How do i get the hub off a vt?
Aug 10, 2016 at 4:27 PM
MHPAUTOS
  • 31,937 POSTS
Take off wheel, caliper and rotor remove abs sensor and hub unbolts from behind, with the new hub in your hand you will see the bolt holes, quite an easy job, don't undo the caliper hydraulic line just lay it aside attached to the hose wire it to the spring so it is out of the way.
Aug 14, 2016 at 4:23 AM
