wheel alignment diagram needed?
2021 HONDA ACCORD
45,000 MILES • 1.5L • 4 CYL • TURBO • 2WD • AUTOMATIC
MAHER_14
I have the car listed above, wheel size 18, and I am looking for wheel alignment diagram because I went to more than one workshop and they did not have enough information.
Apr 2, 2023 at 7:57 PM
Sure, here are the front and rear end alignment specs and instructions on how to make adjustments in the images below. Please let us know if you need anything else to get the problem fixed.
Apr 3, 2023 at 11:32 AM
MAHER_14
Thank you for your help, but I want a simple explanation like the attached picture if possible or close to it (this is the alignment of my friend's car) and thanks again.
Apr 3, 2023 at 6:04 PM
Sorry, the above instructions are all they give us. Where did you get the readout shown?
Apr 4, 2023 at 10:07 AM
MAHER_14
Thank you for the information. My friend sent it to me when he changed the tires of his car, and the same shop did the alignment of the tires, and I do not know if it is correct or not, the shop is in Saudi Arabia
Apr 7, 2023 at 10:05 AM
The readings look correct. What kind of problems are you having or are you just confirming the specs?
Apr 10, 2023 at 10:13 AM
