When you're driving on a straight, flat road, the steering wheel should be straight, not turned to either side. The last step of every alignment is we put the steering wheel perfectly straight and lock it there, then we adjust each front wheel, one at a time, to be steering perfectly straight ahead. Assuming we did a careful job, you will have a straight steering wheel when driving. Months or years later, if something changed or shifted related to the alignment, it will usually cause the steering wheel to be off-center. That is one of the three clues an alignment may be necessary.
This is actually a little more complicated than it would seem. A lot of people are confused between the off-center steering wheel vs one that is turned to one side because you're fighting a pull. If you let go of the steering wheel and the vehicle pulls or drifts toward the ditch, you have to grab the steering wheel and turn it to the left to prevent going into the ditch. That is counteracting a pull. That's not the same as a simple off-center steering wheel. Either condition can be caused by an alignment problem. A pull could also be caused by a tire pull. This is where the numbers on the computer screen tell us what to look for. We identify a tire pull by switching tire locations. For example, if you have a left-hand pull now, then switch the two front tires side to side and then have a pull to the right, it's a tire pull. An alignment won't solve that. Also, since you're rotating the tires regularly, if a pull shows up immediately after the rotation, it is likely caused by one of the tires that was on the back and is now on the front. That's another clue that an alignment won't solve the pull.
The bottom line, as I described previously, is there's three things you can observe to tell when an alignment may be needed. If the vehicle goes straight when you let go of the steering wheel, if the steering wheel is straight when driving on a straight road, and tire wear patterns. Only the tire wear patterns have to be watched for a long time before they show up.
The numbers on your printout suggest the vehicle should pull to the left when you let go of the steering wheel. If that disagrees with what you see when driving, it means your vehicle is rather forgiving of the mismatched camber, then, since both values are in green, it means they're both in specs as far as best tire wear. This is why I said there's always room for improvement, but considering the cost, an alignment is probably not a good value right now. You won't see much improvement for the money spent.
Feb 1, 2024 at 5:32 PM
