Bent Rim
2014 SUZUKI
200 MILES • 4WD • AUTOMATIC
GAVIN GIBSON
I have a four-wheeler but it is kind of the same as a car, I mean the problem I feel would be the same. so I got hit by a truck and it bent up my rim so I replaced the rim and tires and the front left tire (standing in front of it) is bent upwards like the brakes and the tire and everything. I looked for a hour or more and the frame is good and tie rod but the joint where the rube caps are at there are three of them in different places are pushed back and down for the bottom to and the top that is connected to tie rod is pushing forward. it is not wobbly just making my tire the top of it go in towards the four-wheeler and the bottom push out away from it. I do not know what it is that is making it do that. The tie rods and the frame are not bent or anything I am wondering if I need to replace the ball joints, but i do not know. it is a Suzuki Kingquad 400 ASI.
Jun 6, 2017 at 7:31 PM
STEVE W.
  • 15,113 POSTS
Would need to see pictures, but I would suspect you have bent the upper A-arms or the mounts for them.
Jun 6, 2017 at 10:03 PM
GAVIN GIBSON
I will send the pictures.
Jun 6, 2017 at 10:04 PM
GAVIN GIBSON
They will not send. I am really trying to get this fixed ASAP. I miss ridding and stuff. is there another way we can talk about it?
Jun 6, 2017 at 10:15 PM
Hi Gavin,
Can you tell me which device you are using to try and upload the images we are having technical difficulties
Jun 9, 2017 at 4:52 PM
