Good morning,
This sounds like the outer CV joint itself.
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
The axle shaft will have to be replaced.. Once it starts making noise, there is nothing you can do to get rid of the noise.
https://www.2carpros.com/articles/replace-cv-axle
PROCEDURE
REMOVE FRONT WHEELS
REMOVE ENGINE UNDER COVER LH
REMOVE ENGINE UNDER COVER RH
DRAIN CONTINUOUSLY VARIABLE TRANSAXLE FLUID (for CVT)
Click here [ K313 (CVT): FRONT DIFFERENTIAL OIL SEAL: REPLACEMENT+ ]
DRAIN AUTOMATIC TRANSAXLE FLUID (for Automatic Transaxle)
Click here [ U341E (AUTOMATIC TRANSMISSION / TRANSAXLE): VALVE BODY ASSEMBLY: REMOVAL+ ]
DRAIN MANUAL TRANSAXLE OIL (for Manual Transaxle)
Click here [ EC65 MANUAL TRANSMISSION / TRANSAXLE: MANUAL TRANSAXLE OIL: REPLACEMENT+ ]
REMOVE FRONT AXLE SHAFT NUT
Using SST and a hammer, release the staked part of the front axle shaft nut.
SST : 09930-00010
NOTICE:
Loosen the staked part of the front axle shaft nut completely, otherwise the threads of the drive shaft may be damaged.
While applying the brakes, remove the front axle shaft nut.
SEPARATE FRONT SPEED SENSOR
Click here [ AXLE AND DIFFERENTIAL: FRONT AXLE HUB: REMOVAL+ ]
SEPARATE TIE ROD END SUB-ASSEMBLY
Click here [ STEERING GEAR / LINKAGE: STEERING GEAR: REMOVAL+ ]
SEPARATE FRONT STABILIZER LINK ASSEMBLY
Click here [ FRONT SUSPENSION: FRONT SHOCK ABSORBER: REMOVAL+ ]
SEPARATE FRONT LOWER NO. 1 SUSPENSION ARM SUB-ASSEMBLY
SEPARATE FRONT DRIVE SHAFT ASSEMBLY
REMOVE FRONT DRIVE SHAFT ASSEMBLY LH
Using SST, remove the front drive shaft assembly LH.
Aug 10, 2020 at 4:03 AM
