Car will crank but not start, tested crankshaft position sensor and it failed, replaced sensor and still no start didn't test new sensor before installing but did after car wouldn't start and it failed the test, tested a new sensor before installing and it was good but vehicle failed to start. removed sensor tested it and all three sensors have the same problem, no continuity between the signal and ground probes of the sensor. i'm sorry it is a three wire sensor. Do my question is, what would cause this to happen?
Jan 16, 2019 at 7:25 AM
