Good morning my name is Roy and I will assist.
The first thing I would do is to check the battery. If you have a voltmeter check the battery voltage. You need at least 12.2 volts.
If not, charge the battery and see if it starts. If it does you need to check the charging system. You need to see 14 to 14.5 volts while running. Alternator failure may be the cause of your issue.
Dec 22, 2017 at 3:13 AM
