Hard starting and running rough?
1997 NISSAN HARDBODY
210,000 MILES • 2.1L • 4 CYL • 2WD • MANUAL
LDUDE97
Am having the same issue u were having with the truck. What end up being the issue?
Jan 7, 2023 at 7:49 PM
I'm not sure which thread you are referring to. Can you explain what is happening? I'll try my best to help.
Jan 7, 2023 at 10:13 PM
LDUDE97
So, whenever I start the car, it idles very rough and the engine stalls. No 'Check Engine Light' is present at any time. I need to feather or depress the gas pedal to keep it from stalling. If I get the engine to somewhat warm up, then it idles very rough. The thing that happened was that I didn’t change the air filter for a while. One day I came from work, and it was idling rough. I pulled the air filter and the filter had disintegrated so some particles from the air filter went inside the intake manifold. It had a code which was the air mass flow sensor, and I replaced it but it’s still doing the same thing. It was running fine before this happened.
Jan 8, 2023 at 4:27 AM
Based on that information, I would recommend cleaning the throttle body. Also, check to make sure there are no vacuum leaks. Here are two links that explain how to perform both:
Let me know if that helps.
Jan 8, 2023 at 3:14 PM
