What type of gear oil should I use?
2014 FORD S-MAX
130,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • MANUAL
ALESSANDRO ALBERTIN
  • 12 POSTS
Hello, I need to change the gearbox oil on this car, can you tell me what kind of oil and where is the overflow screw? This model has 6 gears.
A thousand thanks.
Jan 19, 2023 at 9:25 PM
Sure, here is the gear oil type with how to change it out in the images below
Motorcraft Dual Clutch Transmission Fluid XT-11-QDC WSS-M2C200-D2 2.01 qt ( 1.9 L) (0- 5 mm below the lower edge of the fill plug hole)
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Jan 20, 2023 at 2:13 PM
ALESSANDRO ALBERTIN
  • 12 POSTS
Very good answer, as always. And picture, help me very much.
Jan 21, 2023 at 12:52 PM
Good to hear, please use 2CarPros anytime we are here to help.
Jan 22, 2023 at 12:20 PM
