Good morning,
The bolts are 8 mm 1.25 pitch about 1 1/4 inches long.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Thermostat Replacement
Removal Procedure
1. Remove the air cleaner and duct assembly.
2. Drain the coolant until the coolant level is below the thermostat.
3. Remove the crossover exhaust pipe.
4. Remove the radiator hose from the thermostat housing.
5. Remove the thermostat housing bolts and clean any sealer from the bolt threads.
6. Remove the thermostat housing and gasket.
7. Remove the thermostat.
8. Clean the mating surfaces.
Feb 7, 2021 at 8:26 AM
