Unfortunately they don't list an option with non A/C. This means you have three options. First, you can try and call the dealer and see if they have a listing for a non A/C option however, I suspect they will not either.
Second, you can get a bypass pulley and remove the compressor and install this in its place, then you can use your existing belt.
Third option is to get a custom size belt but this would require you measure the distance around the pulley less the compressor. This is pretty easy. You just route a piece of string around the pulleys as the belt would go and then make it. Then remove the string and measure it with a tape measure.
Again, due to it not having listing, we wouldn't know the size of the belt without measuring it ourselves. Let me know if you have questions. Thanks
Apr 16, 2020 at 7:16 AM
