Hi Jerome,
This could be made to work but it does not appear to just bolt in. They are different part numbers so unfortunately the only real way is to try it. The way to remove these seats is to just remove the four bolts on the seat track and it should come right out. Again, the tracks are different part numbers so they are different. However, as I stated, if they are close then I am sure you can make a mounting bracket out of metal that you can bolt to the seat track that can then fit in the mounting holes.
Sorry I couldn't give you a definitive answer but I just can't find anyone that has done this on the internet either so if it works or if you make something to get it to work, please post it here and you can be the first. Thanks
Jul 26, 2019 at 5:18 PM
