what scanner will actually tell me which rear wheel speed sensor is bad?
2013 MERCEDES BENZ SPRINTER
38,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
JONNEEANGEL
Have a 2013 mercedes sprinter 3500 rv with 3.0 liter
engine. I need a low cost scanner which will absolutely
work on a 2013 sprinter to diagnose faulty rear wheel sensor , which one. NO one in the country seems to be
able to answer this question absolutely for me. You may
very well be the only genius in this country if you can
answer this question for me without me having to jack
this thing up and take a ohm reading at each wheel to see
which sensor is bad. I will give you an honorary genius
certificate if you can answer this question for me. Thanks
Mar 11, 2020 at 11:01 AM
