Unfortunately we don't have a manual on this vehicle as it is not offered here in the USA but we always check transmission fluid when the engine is to operating temperature.
Here are a couple standard guides that will help with servicing a unit but they show how to check it when it is filled back up:
https://www.youtube.com/watch?v=pHPkHP4m0SM
Most all vehicles from the early 2000s have a sliding scale that you can check the temperature and then it will tell you where on the dipstick the fluid needs to be for that temperature. That is simply to add the mechanic in cutting down the time they have to wait before checking the fluid.
I would suggest checking your dipstick for a full mark and then just get the engine hot. Then check the fluid and fill it to that mark.
Please let us know if you have other questions on this or still need more info and we will see what we can find. Thanks
May 29, 2021 at 6:46 AM
