I was having trouble with a rough idle so I replaced the coolant sensor and its connecting plug. When I go to start it with the coolant sensor plugged in it sputters and does a big air gasp at half throttle. If I unplug that sensor the car runs quite a bit better but of course the CEL is on. Now the sensor I am referring to is the one located on the intake manifold. Is that the only coolant sensor that gives feedback to PCM? Or do the other two sensors meaning the single wire that screws into the head and the fan switch on the thermostat housing also give feedback to the PCM? I am at wits end, when the car is parked the throttle seems to work fine, I put it under a load it sputters and falls on its face. Going uphill it cuts out if I push it farther than half throttle. Give me a direction to go here. I am going to replace the fuel filter today and check the fuel pump pressure also. I have replaced every other sensor on the car. I am going to the salvage yard to get another ECM from another car like mine. If that does not fix it I have no clue. Help!
Sep 6, 2018 at 9:37 AM
